M
Kopieren en plakken van redrc, maar te leuk om dat niet te doen:
SC10 - 360°
Het lijkt erop dat ze de T4 hebben gepakt en er een leuk kapje en dito banden op gezet hebben. Ziet er erg tof uit naar mijn mening!
M
SC10 - 360°
M
Finally, you can now have Team Associated’s world-class performance with true scale authenticity in a 1:10 scale electric short course truck! Team Associated is proud to bring to you the SC10—a 1:10 scale electric 2WD off road, authentic short course race-truck kit.
Based on a lengthened version of the 6-time ROAR National Championship-winning RC10T4, the engineers behind the doors in Area-51 made the SC10 both all show and all go! The result is the SC10 kit, an authentic scale racing experience.
The SC10 comes ready to assemble with a clear short course race-truck body, KMC™ style wheels, aggressive tread multi-terrain tires, all which have been designed to look just like the full-size race trucks that run in short course off-road series around the country. The world of high-performance 1:10 scale electric R/C has never before seen this level of scale accuracy! It’s easy to see that the SC10 is another champion by design!
SC10 Kit Features:
* Based on a lengthened version of the 6-time National Champion RC10T4 platform
* Realistic short course racing truck .040” polycarbonate body
* Chassis side nerf bars
* Trick KMC™ style wheels and aggressive tread multi-terrain scale tires with re-enforced sidewalls
* Realistic bumpers front and rear for maximum durability
* Rubber AE logo mud flaps
* 2.6:1 ratio gearbox equipped with sealed gear differential
* Two spur gears included: 75 tooth for brushless stock and 87 tooth for brushed and modified motors
* Efficient dual-sided, externally adjustable slipper clutch
* Molded composite low-CG chassis
* Hinged battery hold-down strap fits up to 8-cell battery pack
* Set-screw secured antenna tube
* Durable front and rear body mounts
* 14 rubber-sealed ball bearings
* Rugged steel turnbuckles for quick and easy suspension adjustments
* Fully adjustable suspension geometry
* Angled bellcrank “coplanar” steering with integral servo saver
* Vertical ball end roll-center adjustments front and rear
* Blue aluminum shock bodies
* Steel dogbone rear axles
* Many Factory Team and Reedy option parts already available!
SC10 Specifications:
Scale: 1:10
Power : Electric
Length: 550mm
Width: 293mm
Track: 245mm
Weight: 2080g
Wheelbase: 327mm
Internal Gear Ratio: 2.6:1
Drive: 2WD
Note: SC10 shown equipped with items NOT included in kit: Reedy battery, XP servo, pinion gear, LRP ESC, motor, and receiver. Body comes clear. Assembly, painting and decals required. Team decals sold separately.
#7027
SC10 1:10 Scale Electric 2WD Short Course Race Truck Kit
Availability: March 2009
Tja, het is voor 4WD nu eenmaal de manier om de beste gewichtsverdeling te verkrijgen...
Betere plaatjes van de X-Ray X10 hierzo:
www.moosi-masters.de :: Thema anzeigen - New Xray Pan Car 1:10
Niet erg innovatief (eerst dacht ik dat ik naar een BMI zonder topdeck keek).
Behalve als de innovatie de electronica zonder draden is![]()
Op RedRC stond anders wel aangegeven dat de Xray ook in een 6cellen variant zal komen. Dat is misschien wel interessant...
Ik hou het ook bij Asso hoor, daar niet van...
Joost.
