Ja ik zal binnenkort eens een foto maken. Moet wel zeggen dat ik die flymentor niet goed werkend krijg. Als ik hem uitzet vliegt hij wel erg stabiel Naja ik ben ook een beginnen. Funcopter! Very nice keep posting pics and upgrades. Soon ill order some.
Mhh. Where did you get the carbon fly'bar'? And those hex screws are the flybar weights right? Didn't it make the FC less responsive? But more stable I think?
Hey Fred He makes them. He has a nice site with Funcopter mods. He does a great job. Different upgrades etc. With enough pics. I like to order the beltdrive. greetzz
the hex screws are weights, you can take them off for even more cyclic response. but with all the screws on, the cyclic response is extremely fast!!!! but you can remove some of the weight and get even faster response but less stable I am not selling the flybar, i didn't think i could bring it to market for less than what they originally sold for, which was $29.99. but I did receive permission from Matt of Ballistic Technology to copy it and make the file available to anyone that wanted it. some talented guys on a US forum created the dxf file which can be ported to g-code so it can be cut on a machine. but you can also print the file out and you will have a full sized template to cut your own. be careful if you use carbon fiber and cut it yourself, you do not want to inhale the carbon fiber dust. i don't know how to upload a file on this site, it will be posted on my dedicated fc site or you can pm me your email and i'll email the file to you i will not post my site url here, you can easily google my screen name
Ik heb mij een funcopter aangeschaft ,volledig met motor sevo's,gyro en regelaar.Vliegklaar gemaakt en even getest. Ik vlieg al een tijd met Trex 450 en kan in een acht vliegen doch niet in een ronde.Had deze heli gekocht om dit te leren .Heb ernstige problemen om te hooveren met deze heli , op de club laten vliegen door ervaren piloten maar ook zij hebben problemen. Veel afgeregeld aan gyro , doch de staart doet het niet zo goed ,vliegt niet stabiel.Is in deze toestand niet voor beginners . Is geleverd met een lipo van 2500 mAh ,zou deze te licht kunnen zijn? Had met het testen even een omheining geraakt ;2 servo's gesneuveld .
Edmond, Je probleem kan meerdere oorzaken hebben, maar zou om te beginnen zeker als eens nazien of er niet teveel speling zit op de tandwielen van je hekrotor, zeker na een crash. Zelf vlieg ik de Funcopter zelfs met een Turnigy 1800mAh. 3S Lipo en dat gaat ook maar is een stuk stabieler met een zwaardere accu. Heb je hem uitgewogen nadat je je accu hebt geplaatst (zwaartepunt)?
Heb zelf een Trex gehad en loop nu ook nog wel een beetje te tobben met de staart. Ik heb een behoorlijk goede gyro (Logictech) en servo (snelle, digitale Hitec), allemaal veel beter dan wat MPX er standaard in zet, maar ik denk dat ik wel e.e.a. nog goed moet afstellen. Ik denk dat je vooral niet moet verwachten die heli net zo strak te krijgen als een 450 CP (het is gewoon een ander concept, hooveren is denk ik niet het sterkste punt, maar je kan er wel makkelijker mee rondvliegen zonder veel risico), nog wat moet proberen in te stellen op de gyro / in je zender. Mogelijk is een iets zwaardere accu ook een optie; op RCGroups lees ik goede ervaringen met 3000-3300 mah 3S of 2600 mah 4S. Persoonlijk zou ik de headspeed wel wat hoger willen zien; daar wordt de staart ook rustiger van en een iets hoger gewicht draagt daar ook aan bij. Bladegrips met minder graden heb ik nog niet gezien van MPX.
Ik heb met succes vervangen de staart rotor met een 500-stijl staart rotor. Ik wil niet worden gezien als Google, zodat een 'spammer' funcoptermods voor foto's en video I have successfully replaced the tail rotor assembly with a 500 style tail rotor assembly. I do not wish to be viewed as a 'spammer' so google funcoptermods for pictures and video
nieuwe video kijken in HD 1080p 7fM4FSisD24[/media] - Upgraded Funcopter: 4s battery and 500 class boom and tail assembly
instructie video, sorry, ik spreek alleen engels instruction video, sorry, I only speak english s8_5NHiC30A[/media] - Funcopter 500 Tail Modification How-To
instelling riemspanning setting belt tension 6LdjObX3UNg[/media] - Setting the Funcoptermods Belt Tension
It looks very nice. I need new servo's after a little crash My tail rotor is turning to slow. Thats why my funcopter spins. Iemand een tweede hands goede gyro?
krijgen een GA-250 van hobbyking, ze hebben ze in voorraad nu. zeer goede gyro, is enige nadeel MOET je gebruik maken van een digitale servo get a ga-250 from hobbyking, they have them in stock right now. very good gyro, only drawback is you MUST use a digital servo
