Te koop Castle Creations Phoenix Edge HV 160 AMP ESC, 12S / 50.4V.
Alexzzz
Moderator
Moderator team
Forum veteraan
Mooie, betrouwbare Castle Creations Phoenix Edge HV 160 AMP ESC, 12S / 50.4V ESC te koop. In zeer goede staat, nooit hard 3D mee gevlogen en had goede koeling.
Nieuwprijs rond de 360 euro. Mag weg voor 225 euro.
Af te halen in Spijkenisse/Rozenburg, of te verzenden.
Unleash the Power of the Auxiliary Advantage!
Introducing the Phoenix Edge Series ESCs, the pinnacle of speed controller technology. These ESCs embody the next evolutionary leap, pushing the boundaries of performance and functionality. The striking white user-programmable auxiliary wire opens up a world of possibilities. Whether it's making mid-flight adjustments to your helicopter's governor gain, using it as an audible beacon to guide you after an unexpected landing, harnessing its RPM output for RPM sensor-supported 3-axis gyros, employing it as an ESC arming lock, or utilizing it as a receiver arming lock, this wire is your gateway to enhanced control and convenience.
Combined with cutting-edge features like data logging, seamless access to Castle's industry-leading software functions, and the flexibility of USB programming through the included Castle Link USB adapter (or via the Castle Link iOS App in conjunction with the B-LINK Bluetooth Adapter), the Phoenix Edge ESCs offer unparalleled versatility and adaptability.
Step into a new era of speed control with Phoenix Edge and experience the ultimate in performance and customization.
Features:
Data Logging:
Available using Castle Link USB adapter and the Castle Link Windows software to read, analyze and store the data recorded on the ESC.
Power System Alerts:
The Edge ESCs are programmed to sound a number of tunes and codes using the motor as well as flashing LED patterns to alert users to certain conditions regarding their power system, such as over temperature, excessive load and locked head speed.
AUX Functionality:
The Edge ESCs offer an AUX LINE, which is the extra white wire connected to the receiver cable. This line may be used for a variety of tasks such as helicopter governor gain input adjustments mid-flight, serve as an audible beacon after an "unexpected landing", act as an RPM output for 3-axis gyros that support RPM sensors, be used as an ESC arming lock or as a receiver arming lock.
Telemetry Capable:
Telemetry has the potential not only to improve the safety of our models by monitoring battery voltages, ESC temperature, and other critical parameters, but it also creates other opportunities to get even more fun out of flying because you’ve essentially reduced the risks of “unknown” inevitable crashes. Think of the benefits to be had from alarms that will sound to warn you when there's interference about or if your receiver battery is running unexpectedly low. Requires purchase of Castle Telemetry Link for S.BUS2 (Item # 010-0152-00) and compatible Futaba Radio or a Castle Telemetry Link for X-BUS (Item# 010-0148-00) and a compatible Spektrum Radio.
Protection Features:
• Arm Lock Key:
When the Arm Lock Key is in the socket, the controller will be incapable of arming.
• RC Arm Lock: The controller will not arm or run when the auxiliary channel is below 50% after connecting the AUX line to an open channel
on your receiver that is programmed to serve as an arm lock switch.
Programmability:
Fully programmable Castle feature set using Castle Link USB adapter and freely downloadable Castle Link Windows software, or the Castle Link iOS App and a B-LINK Bluetooth Adapter (A small subset of the settings available through Castle Link Windows software can be accessed via manual programming through the transmitter stick).
Firmware Upgrade:
Users will receive free access to all firmware updates, including added features sets using the Castle Link USB Programming Kit
Castle Link Compatible:
With the Castle Link USB Programming Kit you can use your Windows™ PC to easily program your controller. Castle Link includes all code for all Castle Link compatible hobby products in one convenient download. Note: Castle Link software requires a Castle Link USB Adapter and a computer that is running Windows. Castle Link is compatible with Windows Vista, Windows 7, Windows 8 and Windows 10. Macintosh users may take advantage of software such as Parallels Desktop, VMware Fusion, or Apple's Boot Camp along with Windows Vista, Windows 7, Windows 8, or Windows 10 to run the Castle Link software, provided the Macintosh has an Intel processor. Macintosh installation is not supported by Castle Creations.
Specifications:
Input Voltage Range:
• MIN: 3S LiPo
• MAX: 12S LiPo
• Max Continuous Amperage at full throttle: 160 amps*
• Max Voltage: 50.4V
• BEC Voltage: N/A
• BEC Output: N/A
Size:
• Width:
2.0" (50.8mm)
• Length: 4.3" (108.4mm)
• Depth: 1.2" (31.5mm)
Weight (w/wires):
• 8.2 oz. (232.8g)
• 5.3 oz. (150.6g) without wires
• Connectors: N/A
Items Needed for Operation:
• Battery connectors (sold separately)
• Motor connectors (sold separately)
Product Use Statements:
This is a high power product with the potential to be very dangerous. Please read the safety information provided with purchase before use.
Application Guidelines:
• 700 class or 800 class helicopters
• Giant Scale fixed wing
Programmability:
Fully programmable Castle feature set using Castle Link USB adapter and freely downloadable Castle Link Windows software or the Castle Link iOS App and a B-LINK Bluetooth Adapter (sold separately).
• Telemetry Link Capable: Yes
• Tech Notes: Receiver voltage input range: 4.8-9v
Additional Castle Link benefits include:
• Access expanded programming and parameters for Castle controllers (see overview below)
• Access to all firmware updates, including added features sets released from Castle Engineering, at no charge.
• Intuitive Demo Mode capability
• Ability to default ESC to factory settings
• Ability to save setup profiles for later use
• Ability to download and view data logs (on applicable controllers)
Bijlagen
    206,6 KB · Weergaven: 23
    268,5 KB · Weergaven: 22
