Als niemand begint, doe ik het wel!
The Savage XS Flux packs in everything you know and love about the neck snapping, standing backflip Savage Flux. A ridiculously powerful Flux brushless powerplant to provide you with the most menacing speed runs, legendary Savage durability that passes the bashing exam with flying colors, innovative TVP technology for a class leading design, and extreme monster truck appearance and ground clearance to conquer it all. Oh, did we mention that it fits in your backpack? That's right, the compact Savage Flux XS goes where the standard size Savage can't. At 2/3 the size of a standard Savage, the Savage XS Flux is the perfect size for backyard tracks.
The Savage XS Flux is built tough with an all-metal drivetrain so it can handle giant jumps and speeds over 65mph. The 4WD system provides excellent traction on any off-road or on-road surface you can throw at it. And it's all built with legendary Savage toughness so you spend more time driving and less time wrenching.
Pre-assembled from the factory, the Savage XS Flux is ready to go right out of the box, including a 2.4GHz radio system and Flux brushless system. Just add your favorite 2S or 3S Li-Po battery pack and start driving!
The all-new 65+ MPH Savage XS Flux - The World's Fastest Mini Monster Truck. PERIOD.
All of the latest HPI kits are now fitted with a comfortable and feature-packed HPI 2.4GHz radio system for supreme control and confidence! The radio features a pistol-grip design with drop-down steering wheel, 3 channel functionality, easy carry handle, fold-down aerial, end point adjustments, servo reversing and steering dual rate. It's also extremely lightweight due to it requiring only four AA batteries.
You won't have to worry about radio crystals or what channel other RC racers are using with our 2.4GHz technology - the radio does all that work for you! The radio prevents frequency conflicts automatically and changes channels if there is any interference. Finally, if you ever lose radio signal or battery power, an electronic failsafe will bring it to a safe and controlled stop. You'll have professional-level control in one easy RTR package!
Tough "Savage style" TVP Chassis
The chassis for the Savage XS Flux is very similar to the nitro-powered Savage that we all know and love - the backbone consists of the TVP (Twin Vertical Plate) design, formed from two 5mm chassis plates, with the diff cases at either end providing significant stiffness and the transmission casing and motor plate forming load-bearing members of the structure.
Flux VEKTOR 4000 Motor
The Flux VEKTOR 4000 motor delivers massive power - plenty of juice for instant wheelies and standing backflips! Option pinion gears are available to fine-tune the speed and torque delivery! The brushless design assures maximum performance with nearly no maintenance required.
Flux VAPOR Pro ESC
With the capacity to handle 2S and 3S LiPo power, the Flux VAPOR Pro electronic speed control can take anything you can possibly throw at it and keep coming back for more! The VAPOR Pro features an integrated cooling fan to keep it cool in tough conditions. The Flux VAPOR Pro ESC is reversible so you can back out of jams with ease. And for maximum adjustability it's fully programmable with our optional #100573 USB Programming Kit.
Waterproof Electronics
The Savage XS Flux has a waterproof receiver box to keep the 2.4GHz receiver protected from the elements for glitch-free operation. A new SF-10W waterproof steering servo and a waterproof VAPOR Pro electronic speed control mean your Savage XS Flux won't be stopped by wet conditions.
LiPo Battery Power
TThe Savage Flux XS is designed to use 2S or 3S LiPo packs. The battery box features vents to keep the battery pack cool, and we suggest using an official Deans® zero-loss battery plug to match the plug on the ESC.
Full Size Electronics
Unlike other small scale vehicles the Savage XS is equipped with full size 1/10th scale electronics, i.e. servo, speed controller, motor, battery and receiver. This gives the Savage XS the power of full size 1/10th scale motors and batteries and also compatibility with a huge range of hop up electronics.
All-metal Transmission Gears
The Savage XS Flux features all-metal transmission gears to make sure that power delivery is uninterrupted and every jolt of power gets from the motor to the tires efficiently and with no worry of damage to the gears. The whole drivetrain runs on ball bearings for optimal efficiency, extra-long runtimes and mega-fast top speeds!
Ultra Tough Over-sized Suspension
The over-sized suspension design makes the Savage XS extremely tough and capable of handling even the wildest bashing action. Aluminium 14mm hex hubs allow the mounting of almost all standard 1/10th scale wheels.
Silicone Filled Threaded Shocks
Four threaded shocks give the suspension action you need to get out and blast through the roughest of tracks or off-road terrain. Filled with silicone oil, the slick nylon bodies are lightweight and strong, with almost no 'stiction' between the shock piston and shock body for smooth and consistent damping.
Protective Chassis
The enclosed Savage XS chassis design protects all components from impact damage. All components like battery, Motor, and servo sit inside the protective chassis.
All-Terrain Tires, 1/10th compatible
With the aggressive tread of the 2.2" GT2 tires, you can go off-road to on-road with predictable handling. The center tread lines give you stability on paved surfaces while the blocky tread pattern and heavy-duty sidewall teeth provide grip for off-road terrain like dirt, mud, muck, leaves. They're mounted on black chrome 2.2" Warlock wheels for tough monster truck styling. For maximum hop-up potential, the Savage XS Flux accepts a wide variety of 1/10th scale 2.2" wheels and tires, making customizing your truck easy.
Pre-Painted Body
The GT-2XS monster truck body is wrapped with a "red flame" paint scheme just like the full size Savage Flux HP. It's completely trimmed with decals pre-applied so you can hit the track quickly.
HPI makes it as easy as possible to get into RC off-road action. The Savage XS Flux is completely pre-built and ready to go right out of the box! Everything is assembled and tuned for you by professionals - diffs, shocks, suspension and more are perfect before you even open the package.
HPI Ready-To-Run vehicles bring you the same high performance and quality that you'd expect from a high end RC kit but with the added convenience of being factory pre-assembled to the highest standards - giving you a high performance RC truck straight from the box!
HPI RTR cars and trucks are 98% factory assembled - they come Ready-To-Run and equipped with all the radio gear required. Just a few steps are needed to get your car up and running, such as adding the batteries to the transmitter and charging up your choice of batteries to fit in the truck!
Just like all HPI cars and trucks, you get a full, in-depth instruction manual with step-by-step instructions that allow you to easily disassemble and reassemble your car for maintenance and easy servicing. The manual also includes a handy parts list and full-scale drawings of the parts and hardware. And the included HPI RC Car DVD is your personal RC car expert in a box!
#106572 RTR SAVAGE XS FLUX
Pre-Assembled 4WD electric powered mini monster truck with 2.4GHz radio system, FLUX VEKTOR 4000Kv brushless motor, FLUX VAPOR PRO waterproof electronic speed control, SF-10W waterproof servo and painted GT-2XS body.
Battery and charger not included.
SPECIFICATIONS:
Length: 360mm
Width: 280mm
Wheelbase: 225mm
Drivetrain: Shaft 4WD WHAT YOU NEED:
- 4 AA Batteries for Transmitter (rechargable recommened #101938)
- Racing battery (7.2V NiMh or 7.4V or 11.1V LiPo)
(recommended HPI Plazma battery #101941 or #101943)
- Charger (recommended HPI Reactor #101971)
Bron: HPI Savage XS RC Car by HPI Racing Europe
Ik kan geen goed fotootje vinden en plaatsen van de motor, maar op de site kan je hem wel bekijken. Hij zit zoals eerder al besproken in één batterybox. Op de foto van de onderkant kan je ook zien dat de ene box anders is.
Dus maar één accu kan erin.
The Worlds Fastest Mini-Monster Truck !
Flux VAPOR Pro ESC
LiPo Battery Power
Protective Chassis
Pre-Painted Body
Savage XS Features Summary
- TF-40/RF-40 2.4GHz radio
- SF10W waterproof servo
- Waterproof receiver box
- Vapor Pro waterproof brushless ESC
- Vektor 4000Kv 1410 4 Pole brushless motor with cooling fan
- Fits standard size 1/10th scale electronics
- Silicone oil filled shocks with threaded bodies
- All-metal bulletproof drivetrain
- 2.2" wheels and tires (can use most 1/10th scale truck wheels and tires)
- Shock towers have multiple shock mounting positions
- Quick access to the front or rear differential by removing just 4 screws
- Cam type servo saver
- Spacious battery box w/locking battery box door
- All socket head hardware
- Dual pad slipper clutch
- Full set of ball bearings
- Aluminum motor plate with 4 motor mounting positions
- Aluminum hex hubs
- TVP (Twin Vertical Plate) chassis
- Integrated chassis carry handle
- Tough 4-gear differentials
- Aluminum front and rear suspension braces
- Stainless steel bulkhead lower plates
- Front and rear skid plate bumpers
SPECIFICATIONS:
Length: 360mm
Width: 280mm
Wheelbase: 225mm
