HPI Trophy Buggy /Truggy Flux topic
Discussie in 'Electro offroad' gestart door rubenbosman, 9 jun 2011.
  1. rubenbosman
    rubenbosman
    24 mei 2008
    Kampen, overijssel
    hier bij het HPI Trophy Buggy/Truggy Flux topic:
    Als je meer informatie hebt of een vraag of wat dan ook wat met deze buggy/truggy te maken heeft zet hem hier neer!
    Fantastically Fast Brushless Buggy Fun!
    The brushless-powered RTR Trophy Buggy Flux from HPI is the go-to kit for all-out fun and excitement combined with mind-bending top speeds! The Trophy Buggy has been a hugely popular 1/8th buggy, and now that it's fitted with the demonically fast Scream brushless motor and the 4S-capable Flux Rage speed controller, you can finally see what all the excitement is about with 1/8th electric buggies at a great price!
    Fully assembled right out of the box and fitted with a no-hassle HPI 2.4GHz radio system, the Trophy Buggy Flux is ready for you to drop in two 2S LiPo batteries for 14.4 volts of ground-crushing fun! Go brushless with the Trophy Buggy Flux!
    Get right into plug-and-go truggy action with the RTR Trophy Truggy Flux! This amazing off-road 4WD vehicle will thrill you with its jaw-dropping top speed, racing design and wild stunt action! Always a popular kit in its Nitro version, the Trophy Truggy has seen it all when it comes to burly stunts, and with the awesome power of a purpose-designed brushless system it is able to pull off the same tricks and as the Nitro version - but without the noise and fumes!
    The Trophy Truggy Flux is completely painted and assembled for you, fitted with a no-crystal HPI 2.4GHz radio system and ready for you to add two 2S LiPo batteries! You'll get to experience 14.4 volts of monster power driving 1965KV of brushless power!
    2.4GHz RADIO SYSTEM
    Ready-built right out of the box and fitted with an all-new 2.4GHz radio system, the Trophy Buggy/truggy Flux is the perfect introduction to serious 1/8th off-road buggies/ truggies! No need to worry about changing crystals, the radio prevents frequency conflicts automatically. If the car ever loses radio signal or battery power, an electronic failsafe will bring it to a safe and controlled stop. You get big-air fun and race-track performance in one easy RTR package!
    Watch the new Trophy Truggy Flux in action!
    If you're looking for a powerful, versatile and FAST brushless system, you don't have to look any further than the combination of the HPI Flux Scream motor and Flux Rage speed controller!
    The Flux Scream motor is the perfect match for the Rage speedo: with 1965KV of power, it was designed from the ground up to be bolted into 1/8th scale off-road vehicles to give you the explosion of power you want from any car or truck!
    The Flux Rage is a monster of a speedo: able to handle twin 2S batteries for up to 4S (14.4 volt!) power, you will experience mind-bending top speeds and blindingly fast acceleration for huge stunts, massive jumps and burly maneuvers that will make your jaw drop!
    Also, if you ever want to change your speedo settings, you'll be able to experiment easily with the #101280 2 in 1 Professional Program Card! You can change the amount of braking the speedo uses on the motor, reversing speed, motor timing and even the motor for accelerating smoothly in different traction conditions!
    The chassis of the Trophy Buggy Flux is based on the nitro version of the Trophy Buggy, so it's ready for anything you can throw at it. The aluminium construction provides the perfect foundation with its combination of low weight and high strength, and the smart design and layout of the components make working on the car fast and easy!
    • 4mm 6061 aluminium chassis has angled sides for extra stiffness
    • Fits two hard-case 2S LiPo batteries with adjustable battery holders and hook & loop straps
    • Low-profile aluminium radio tray securely mounts servos
    • Tough front bumper protects against crash damage
    • Enclosed radio box protects battery and receiver from the elements
    • Low centre of gravity design for top handling in the turns
    • Adjustable mounts for the wide racing wing
    Formed from 4mm thick 6061 aluminium, the chassis of the Trophy Truggy Flux features angled sides and a huge vertical rear brace for phenomenal stiffness front-to-rear. The twin batteries fit securely within adjustable and padded battery box, held in place with two thick hook-and-loop strips so they won't move during jumps or crashes. The layout of the components within the chassis makes it easy to change batteries, and a breeze to do maintenance!
    • Tough front and rear bumpers help protect against crash damage
    The Trophy Buggy Flux uses a suspension taken directly from top racing truggies - it was designed from the ground up to be tough, reliable and adjustable for any type of terrain, whether it's a BMX jump trail or a top-level racing track! The suspension is fully adjustable and equipped with turnbuckles, multiple shock mount and camber link locations, sway bars and more.
    And when it comes time to work on the suspension parts, replacing things is a quick and easy matter! Drop in upgraded options or swap out spares right at the trackside!
    • Proven race geometry with championship-inspired design. The zero kingpin 'inverse angle block' design is a definite winner, and out on the track it will give you the confidence you desire as you go head to head against the club pros!
    • Thick 6061 aluminium shock towers offer performance tuning and strong construction
    • Extra-strong webbed suspension arms are strength yet flexible to tackle give you the best balance of driving feel and durability
    • Cast aluminium steering knuckles for increased strength
    • Extra-long shocks provide all the damping you'll ever need
    • Race-tune your buggy with plenty of shock adjustment positions
    • Strong steel turnbuckles with chunky gripping points for easy adjustment of camber and front toe.
    • Multiple camber link locations offer several options for adjusting roll centre
    • Thick rear sway bar fitted for superior race handling
    • 17mm hex hubs resist stripping out and are hollow for light weight
    The Trophy Truggy Flux uses a racing-derived suspension design that's perfect for racing, stunts, bashing - pretty much anything you want to do! The suspension has loads of features that are standard on all the top racing kits: extra-long suspension arms, aluminium steering knuckles, adjustable wheelbase and 17mm hex hubs.
    For increased durability when hitting those big air highs and rough-and-tumble landings, the Trophy Truggy Flux uses hinge pin braces, captured rod end joints on the camber links and thick webbing on the plastic parts to resist breakages. Use the steel turnbuckles and variety of shock mount and camber link positions to tune your truck to your driving style, the track and the driving conditions!
    • Race-tune the truck with plenty of shock adjustment positions
    HPI makes it as easy as possible to get into RC Off-Road action. The Trophy Buggy Flux is completely pre-built and ready to go right out of the box! Everything is assembled and tuned for you by professionals - diffs, shocks, suspension and more are perfect before you even open the package. And with many top racing features already installed, you don't have to do a thing to get going fast!
    HPI Ready-To-Run vehicles bring you the same high performance and quality that you'd expect from a high end RC kit but with the added convenience of being factory pre-assembled to the highest standards - giving you a high performance RC truck straight from the box!
    The bodyshell is new on the Trophy Buggy Flux, with a super-cool multi-colour paint scheme designed by Jon Miller from RCS Graphicworx.
    Just like all HPI cars and trucks, you get a full, in-depth instruction manual with step-by-step instructions that allow you to easily disassemble and reassemble your truck for maintenance and easy servicing. The manual also includes a handy parts list and full-scale drawings of the parts and hardware. And the included HPI RC Car DVD is your personal RC car expert in a box!
    #101706 RTR TROPHY BUGGY FLUX W/ 2.4GHz
    1/8th Scale 4WD Electric Rallycross Buggy with
    Flux Scream Brushless Motor,
    Flux Rage Speed Controller,
    2.4GHz Radio System and Painted Body
    SPECIFICATIONS:
    Length: 500mm
    Width: 305mm
    Height: 179mm
    Wheelbase: 320mm (adjustable)
    Track Width Front/Rear (from centre of tyres): 260mm
    Tyres: 40mm wide x 110mm (outer diameter), 80mm inner diameter
    Drivetrain: Full-Time Shaft 4WD
    WHAT YOU NEED:
    4 AA Batteries for Transmitter
    2 2S LiPo batteries with Deans Ultra plugs
    (we suggest #101940 #101941 or #101942 HPI Plazma battery packs!)
    #101707 RTR TROPHY TRUGGY FLUX W/ 2.4GHz
    1/8th Scale 4WD Electric Truggy with
    SPECIFICATIONS:
    Length: 580mm
    Width: 405mm
    Height: 180mm
    Wheelbase: 365mm
    Track Width Front/Rear (from centre of tyres): 365mm
    Drivetrain: Full-Time Shaft 4WD WHAT YOU NEED:
  2. Auto-G
    Auto-G
    26 feb 2011
    Nette startpost, hoe heten de regelaar en motor van hobbywing nou?
    Tis nog eventjes wachten op deze wagen maar ga je hem halen?
    Blijf zelf bij de vorza.
    Er zijn wel aardig wat parts die overeen komen ermee, dus kan je er ook bepaalde vorza of d8 stukken op zetten
    Mooi ding iig, benieuwd wat ie hier gaat kosten
  3. rubenbosman
    rubenbosman
    24 mei 2008
    Kampen, overijssel
    over de kosten word ik zodra het bekend is geïnformeerd,
    en deze gaat zeker op het "wil hebben" lijstje:yes:
  4. rubenbosman
    rubenbosman
    24 mei 2008
    Kampen, overijssel
    nou ik hoop dat de startpost zo goed is... :cool:
  5. mikeon
    mikeon
    24 mei 2010
    Zoetermeer
    Ik heb de brandstof versie, leuk dingetje hoor.
  6. Psygho (Emil)
    Psygho (Emil) Forum veteraan
    7 jan 2004
    Prov. Drenthe.
    +1 voor de openingspost!
    Emil, mod
    Mooi ding btw...
  7. areon
    areon
    23 jul 2009
    Wateringen
    startpost +1 !
    En wat een gaaf ding...!
  8. Hackroader
    Hackroader
    12 sep 2009
    Arnhem
    zeer nette startpost :yes:
    wat is dat voor esc ?
    lijkt weer op een hobbywing , deze keer de hobbywing sc8 of sc10 esc ? (wel modified by HPI natuurlijk)
  9. FireFrenzy
    FireFrenzy
    22 jun 2009
    Utrecht
    Damn fine wielen ook... (ik moet eerlijk toegeven weinig tot niets met dishes te hebben)
  10. rubenbosman
    rubenbosman
    24 mei 2008
    Kampen, overijssel
    moet ik hier een algemeen trophy topic van maken?
    buggy en truggy?
    chassis is bijna hetzelfde :yes:
  11. Hackroader
    Hackroader
    12 sep 2009
    Arnhem
    ja , lijkt me wel handig zijn namelijk nagenoeg dezelfde wagens.
    (same as Bullet ST/MT)
  12. darkfire
    darkfire
    4 jun 2010
    Diepenveen, Overijsel
  13. rubenbosman
    rubenbosman
    24 mei 2008
    Kampen, overijssel
    ja ik heb het gezien, ik heb de startpost maar weer aangepast, zodat de buggy en truggy er staan.
    wel door elkaar maar dat vond ik wel goed staan :yes:
  14. darkfire
    darkfire
    4 jun 2010
    de truggy is echt langer door dat tussen de chassis en de shocktower van de truggy is het wat verlengt.
    is het dan nog wel stevig of is het een breekpunt?
    welke zal meer all-round zijn?
    ik voel gewoon dat meer mensen twijfelen.
    is het denk je slim om andere stekkers aan te solderen?
    Laatst bewerkt: 9 jun 2011
  15. Hackroader
    Hackroader
    12 sep 2009
    Arnhem
    het IS een verbeterde hobbyking (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9127) , check this out :
  16. rubenbosman
    rubenbosman
    24 mei 2008
    Kampen, overijssel
    ze zien er wel allebei super degelijk uit..
  17. snellehenk
    snellehenk
    10 okt 2007
    Zoetermeer
    Ahum, de Turnigy combo van Hobbyking is eigenlijk een Hobbywing XeRun setje met een ander naampje, net zoals HPI dat doet.
    Volgens mij zit de M3A combo in de HPI's:
    HOBBYWING TECHNOLOGY Co., Ltd.,
  18. Hackroader
    Hackroader
    12 sep 2009
    Arnhem
    dat zou heel goed kunnen ja.
    alleen die motoren hebben een andere KV waarde.
  19. rubenbosman
    rubenbosman
    24 mei 2008
    Kampen, overijssel
    kijkend naar de bullet flux modellen, vraag ik me wel af of deze motoren wel genoeg kracht hebben...
  20. Hackroader
    Hackroader
    12 sep 2009
    Arnhem
    dat zal je verbazen , paul benard van het forum heeft met een hobbywing motor de 147 km/h gehaald en doet standing backflips... (wel met een 1:10 2wd auto en 2700kv maar het is en blijft een hobbywing)
    die motors waren ook heel niet slecht volgens mij , die dingen liepen keihard en deden gewoon wheely's...
    Laatst bewerkt: 10 jun 2011
