Dear rc friends,
This is a new Wood Over Foam (WOF) F1 tunnel hull of my own design. As you will see in the photos the project is at an advanced stage because first I wanted to see if I could handle this new building technique. Overall, it is a wide and low profile (the height of the tunnel is 2 cm) design which adopts a number of characteristics from other designers of rc f1 hulls (see e.g. Jerry Dunlap (WOF), Dirk Jan (Cosy and Cosy T800), F1madness79, Zipkits G30 and others) and also from real F1 boats (e.g. the air steps or the center keel). I hope that this design will make the hull stable at cornering and less prone to flipping (due to less amount of air under the hull), but this is something that I will see in practice; maybe I am wrong
who knows
The specs of the model are:
- Total length: ~73 cm,
- Beam: 32 cm,
- Sponsors: length 70 cm, width 7 cm with air pads at the bow,
- Running pads: dead rise angle 11 degrees, width 4cm with 2 air steps,
- Center section: length 57.5 cm, width 18 cm with a center keel and an air step,
- Outboard: DIY bullet outboard,
- Engine: 3674, 2200 kv,
- Esc: 150 Amp, Flycolor
- Lipo: 4S-5S
- Propeller : I may start with a 40mm 1.4 pitch.
- Beam: 32 cm,
- Lipo: 4S-5S
