Dutch Tamiya Challenge 2012
Had al een mailtje gehad van Ted, Michael;)
Komt goed.
Ga ik vanavond regelen als ik op tijd thuis ben.
Was gisteren ook pas 21:30 uur thuis:( na om 07:00 uur gestart te zijn8-O
mvg Roy
Hey Hugo, Klopt voor de F1:)
Daar wist ik mijn transponder nummer nog van uit mijn hoofd.
TC moet ik nog ffies achterhalen en dan komt die er ook bij.
Kan ik zowiezo Ted gaan pesten want die staat al ingeschreven:cool:
Zow TC ook geregeld, dus weer een inschrijving er bij:D
mvg Roy
Hi Phil,
This year you can choice between the Carson Cupmachine and the Tamiya Formula tuned motor.
The Cupmachine will be available at the track for €10,-.
The Tamiya Formula tuned you have to buy yourself.
Both motors are available at the LHS that can order from Rapid Hobby Import.
Hope to see you soon.
Grt,
Michael
Depends on the one you want to run Phil.
The Carson is sold by the DTC and the Formula tuned is sold true your LHS and or fleebay.
I got a Carson here you can use and test your F1 with if you want?
regards Roy
It depends Phil, the Formula tuned is slower in RPM(Carson about 21000 rpm and the Formula tuned 14,000 rpm) but has a lot more torque the the Carson.
If you overgear the Carson it is the end of the motor as is can't stand a bit of heat.
The Formula tuned can run a lot bigger pinion's then the carson without any problems.
When running the Carson for example with 93/29 on a tech track it will destroy the motor as it builds up heat to much.
The Formula motor can take a lot of beating before it is destroyed.
Going to run the Formula motor this weekend with 93/32 to see what it is doing on out track(heat,speed and track time).
regards Roy
ok cool then i will go looking for the formula tuned motor , not very good with gearing so it is one less thing to worry about
thanks matey
Where did you get your Formula motor from ??? cannot seem to find one here in NL
Phil, the Holy Cow in Deventer has got them for a nice price.
I need also one, so must I order 2 of these, one for you and one for me?
Martijn
Beste rijders,
Wegens werkzaamheden aan de baan van MRM kan er zaterdag 24 maart niet gereden worden. Zondag kan er wel worden gereden echter met gebruik van een beperkt gedeelte van de rijders stelling. ;)
Dit voor degene die willen komen trainen voor de eerste wedstrijd van het nieuwe seizoen DTC :D
Gr. Rene
Electron pm van mij. Ik hoop dat het gaat werken als ik die Tamiya Receiver Regulator TRO-01- BEC aansluit aan mijn Traxxas TQI receiver. Want ik kan weinig op het internet vinden voor oplossingen: TEU-101 BK samen een Traxxas TQI receiver.
Wil namelijk wel heel graag aan het DTC meedoen.
Zijn er eigenlijk deelnemers die uit Utrecht komen?
Dat is zo als ik kan zien geen regelaar maar een BEC systeem?
Als jij een beetje nette regelaar hebt zorgt deze er voor dat de ontvanger de juiste spanning krijgt.
mvg Roy
Heeft er iemand deze regelaar over?
I have bought an F104Pro
If i want to do the X1 side shock conversion can I ??
What other things do i need to do to get it to drive well on the E.T.S tyres ???
Thanks Phil
Thanks Phil
Hi Phil,
Yes you can!
There is a side tube conversion for the normal F104.
Don't know how the ETS tires drive on asfalt.
On carpet there fine.
Grt,
Michael
