Nieuwe releases HPI Racing
Wil er opzich ook wel meer over weten..
De motor in de firestorm enz is een castle sidewinder, die in mijn vorza een mamba monster.. kan goed weer een castle zijn want volgens mij hebben ze een partnership
Edit had dit gevonden eerst: ein Hobbywing 150A Regler mit einem Leopard Motor.
of het klopt weet ik niet.
If you're looking for a powerful, versatile and FAST brushless system, you don't have to look any further than the combination of the HPI Flux Scream motor and Flux Rage speed controller!
The Flux Scream motor is the perfect match for the Rage speedo: with 1965KV of power, it was designed from the ground up to be bolted into 1/8th scale off-road vehicles to give you the explosion of power you want from any car or truck!
The Flux Rage is a monster of a speedo: able to handle twin 2S batteries for up to 4S (14.8 volt!) power, you will experience mind-bending top speeds and blindingly fast acceleration for huge stunts, massive jumps and burly maneuvers that will make your jaw drop!
Also, if you ever want to change your speedo settings, you'll be able to experiment easily with the #101280 2 in 1 Professional Program Card! You can change the amount of braking the speedo uses on the motor, reversing speed, motor timing and even the motor for accelerating smoothly in different traction conditions
