[QUOTE="
Nu nog uitvogelen hoe de auto launch werkt...
Groeten, Jan.[/QUOTE]
Hallo Jan
Handleiding gelezen?
One click return home, the plane will return home automatically when it was out of RTH range, this mode can be used for assist hand-launch, you can switch to this mode on ground, pull the throttle to 80%-100%, in this moment the throttle is not activated, when the plane flying speed is >4m/s, the throttle will be activated, you can hand-launch the plane and it will automatically climb to 35m height and auto-hovering in a circle
oh en dit staat er ook in:
Q:I powered on the plane, after the Kopilot working, shortly the motor is working by itself (or the motor keep beeping), what is the reason?
A:The throttle range is not calibrated, please switch to manual mode, process the throttle range calibration according to the ESC manual.
groet Hans
ps onderstaande heb ik eens ergens op internet gevonden:
ZOHD autopilot info
correct no power to motor without GPS lock in RTH or STAB mode...to help prevent fly aways
Neutral calibration solution ( oplossing)
Neutral cal is done with the sticks. Radio cal is done with the settings module. The manual is correct. I’ve installed and calibrated four of these so far and the instructions are correct and work.
Start with a new model as the manual instructs. Do not set up any mixes. AETR 100%. No dual rates
Connect everything per manual
Select the plane type
Check surface direction with manual and then in stabilized mode. Correct things as needed to get it working right. Reverse channels in the radio and/ or in KP pots to make it work right
Do neutral cal
Do radio cal
Importantly, fly the plane in manual and get trims right. Adjust pushrods so that trims can be close to middle position. Then redo the radio cal. Then fly in Stab mode and enjoy your flight!
Solution was to reverse channels 1, 2 and 4. Throttle and rudder are both -100 when sticks are bottom right, aileron and elevator are +100 sticks bottom left. This for a Taranis and Frsky SBUS receiver.
Hallo Jan
groet Hans
ZOHD autopilot info
Do neutral cal
Do radio cal
