Ariel
PH-SAM
Yep, dat is't. Maar wat is het?
Een vliegtuig!
Johannes
The Boeing L-15 Scout or YL-15 was a small, piston engine liaison aircraft built by Boeing in very small numbers after World War II. It was a short take-off and landing (STOL) aircraft powered by a 125 hp Lycoming engine. The L-15 was an attempt by Boeing to expand its product line as World War II drew to a close and Boeing's production of combat aircraft declined. Boeing decided against marketing the L-15 as a general aviation aircraft, and the few that were produced went to the United States Army. Most were used in Alaska for various duties. (Wiki)
A liaison aircraft (also called an army co-operation aircraft) is a small, usually unarmed aircraft developed before World War II and primarily used by military forces for artillery observation or transporting commanders and messengers. The aircraft were also used for battlefield reconnaissance, air ambulance, column control, light cargo delivery and similar duties. Able to operate from small, unimproved fields under primitive conditions, with STOL capabilities, most liaison aircraft were developed from, or were later used as general aviation light planes. Today, the helicopter performs the duties formerly accomplished by liaison aircraft. (Wiki)
