Met deze setup haalt de baiojet maar 285km/u!
De baiojet is namelijk iets groter dan de Funjet Ultra.
Grtz René
How do you know the baijo will only fly 285 for one its lighter than the funjet straight out of the box
the wings are hollow and its more streamlined = Less drag
secondly its very arrogant to claim that the funjet will fly faster with the turnigy or kontronik setup when no comparison has been made and ive never seen anyone in the netherlands fly a baiojet jet yet to make a comparison
Finally as none of these motors you mentioned will fit in the fusleage of the baiojet as there outer diameter exceeds the inner diameter of the baiojet by 4 mm which would be a bit difficult for an outrunner to work i reckon. i dont see how you can make such a claim or was it just a guesstemation !!!
fyi
out of box weight funjet 875 gram
out of box weight baiojet 550 gram
wingspan funjet 780
wingpan baijo 840
oh and dont forget wingloading
makes the aircraft more difficult to handle the higher the wingloading gets which would then require a higher power output to achive high speed !!!
total weight for mine now just measured with servos, motor, 6 cell lipo, 120 amp esc
= 1090 grams
theres no way you can achieve such a low flying weight with the funjet as its 875 grams before you even start and if i put the same setup i have im my funjet i get a all up weight of 1450 grams
yours would be higher due to the weight of the motors your using and therefore would require more power to get it to similar speeds and obviously from all your claims dont know the first thing about aerodynamics
